Results 1 to 10 of 10
    Barnoldswick
    Engine build
    Hi all,
    Just a few questions for you.
    Piper 285 cams, are they all re profilled now? Not form blanks? Does anyone sell the full kit at a discount rate, for buying full kit? Cam, pulley and springs?
    Pistons and liners, where to buy new ones? Just std.
    Oil pump, havent had a guage on yet but should i just shim it if internals look ok?
    Gasket sets, top and bottom, gsf??
    Timing chain and tensioner from.....
    Probabilly forgotten a few questions!
    Cheers Chris
    Non-member royz's Avatar
    stockport
    Re: Engine build
    piper still do the cam from a blank. cost a bit more and is made to order. I got my cam kit complete from ric wood in stockport. it had the springs cam and pully for £380 at the time.
    Re: Engine build
    I think mike 16v r5gt turbo spares gas piper cams if not cgb. Same for liners etc. In fact get the whole lot from Mike or cgb and you will get a club discount from Mike.
    Barnoldswick
    Re: Engine build
    Cgb lists some piston and liners as a kit for 200.00 what make will these be? Anyone used these?
    Also, i know the difference about re profiled cam, but why opt for a blank?
    Non-member GTphil's Avatar
    Re: Engine build
    A reprofiled cam can make the engine sound a bit more tappy can require more adjustment of the pully for timing it where you want it. My 285 was from a blank and for 113 degrees it only needs a very slight adjustment of the pully. It is also as quiet as the o.e cam was tapper wise.
    Both engines I have installed this cam in both timed up to 112 degrees without any adjustment at all.
    My guess is with a regrind that probably wouldn't happen.
    Barnoldswick
    Re: Engine build
    I'll go for a blank if when i strip engine i find liners etc ok.
    There was a bit of a tap when running, couldnt decide if piston or just a tappet! Will have a look when stripping engine.
    Currently cutting rot out and welding
    Barnoldswick
    Re: Engine build
    Gutted, few of the liners corroded and marked, pistons look to have polished slightly on skirts. Big ends wernt the best, bit of transfer on the crank from a shell but came off with a light sand and wd40.
    On the plus side just ordered new pistons and liners and all gear to re build engine
    Feb 2012
    Re: Engine build
    I wouldn't use the crank without getting it polished up properly . Or even ground to .25 better safe than sorry dude .
    Re: Engine build
    While it's all apart its worth having the crank checked by an engine shop, maybe get the head looked at too.
    Norwich
    Re: Engine build
    Wise words mate, defo get crank checked as it may require a polish/re-grind. Also get pressure tested/skimmed as required.
