Results 1 to 2 of 2
    Non-member Schakal's Avatar
    Barry
    fuel pressure regulator
    some of you know i am still trying to start the engine up
    on the fuego turbo i had for free
    after going over the usual stuff ,finally found there is a fuel delivery problem
    which seems to be related to the fuel pressure regulator(possibly blocking flow ) but before sourcing another one i really want to start the engine up to see whats what .
    my question is , will the engine start up/run allright with the
    fuel pressure reg. removed/by passed from the system ?
    Dublin/Ireland
    Re: fuel pressure regulator
    it sould do yes,but it will be at full pump pressure so u can bleed some off using a tee-piece back to the return line!
