Results 1 to 5 of 5
    Jul 2012
    how to
    Good evening all, i need a little help and advice, i cut the connector off from under the water bottle amd now i'm not sure which wire goes where, does anyone know how to test which wire is which, i still have the block on the side that goes in to the car so i can follow haynes but tbe other side that goes to the oil sensor, alternator ect I'm not sure so i need to know how to check as some of the wires are the same colour
    thanks
    Norwich
    Re: how to
    Ah I see, take it you didnt label each wire when you removed the 'connector of death' ?
    Re: how to
    Article on replacing the connector of doom:
    https://www.rtoc.org/boards/showthread.php?t=37236
    Linked thread on the article, pointing to an engine loom picture/description:
    https://www.rtoc.org/boards/showthread.php?t=27173
    Maybe doesn't answer everything you need to know, in terms of which coloured wire goes where but it should help. Maybe if you find out you can put the details up on here
    Jul 2012
    Re: how to
    I removed it almost 10 years ago and only now am i putting the car back together. I must have just cut it off at the time of stripping.
    Re: how to
    Good opportunity to do the replacement idea in the article
