Results 1 to 9 of 9
    Non-member LYNCHSTAR's Avatar
    alternator
    would my alternator be knackerd if the battery light does not come on the dashboard. also if car is leftfor days the battery goes flat. would this effect the cars performance to all of a sudern mines running ****e.
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: alternator
    you need to test your alternator by using a multimeter and it needs to be reading above 13. if your battery goes flat it either on its way out or something is drawing power from it.
    Dec 2004
    Aylesbury
    Re: alternator
    Quote Originally Posted by 6129 View Post
    If the light doesn't come on the dash then no the alternator is ok but i've had 1 or 2 cars that no light has come on but it didn't charge the battery so check the charge with a multimeter.
    To be honest it sounds like the battery is on its last legs if its loosing charge after a while.
    Dublin/Ireland
    Re: alternator
    check the alt. earth and wiring,then check the bat. bulb first
    Re: alternator
    i brought a new battery and still no battery light.
    Dec 2004
    Aylesbury
    Re: alternator
    Do you mean when you turn the ignition on you have no ignition light?
    Re: alternator
    yes mate no ignition light. my car would not turn over so i put a cable from the starter motor to battery to jump it because the solenoid was stuck ever since i did that the ignition light did not come on and the battery ran down after a couple of days the performance is a bit ****e aswell would this have anything to do with it aswell.
    Non-member MR TURBO's Avatar
    bristol
    Re: alternator
    Is that cable still connected??
    Re: alternator
    Quote Originally Posted by MR TURBO View Post
    no mate.
