Run my car with just a maunal fan switch so no low temp fan switch needed.
What is best a normal temp radiator hose thermostat or a low temp one? Does it really matter?
you dont need a low temp stat or switch if your cooling system is efficient.
Low temperature thermostats & rad' fan switches = Fail.
O.E parts/operating temp's FTW.
I have not had a problem with my OEM setup, I just flush the cooling system each year.
