Results 1 to 37 of 37
    Apr 2011
    An early whats left to do for FCS/national day
    Yes I know its very early to be talking about this but with the amount of work ive still to do to my car the 12 weeks that's left doesn't leave me with much timeespecially as I know how slow I work
    Here is my list of the jobs that I need to do in no particular order, im going to forget some but will add them when I remember and more importantly for me I will tick them off as and when I complete them
    #### means job jobbed.
    1, Finish off stitch welding my subframe ####
    2, Weld in brace on wishbones ####
    3, Sand and paint driveshafts, steering rack, track rod ends and basically anything that cant be powder coated
    4, Send all brackets, suspension parts, mounts etc off to be powder coated inc the subframe ####
    5, Clean up and repaint my spax front shocks
    6, Fit shocks up with new bushes, top mounts and bearings
    7, Take off the rest of the aftermarket sideskirts and then cut out the rotten part of the sill and weld in the new pattern sills that ive got
    8, Add abit of fibreglass to the o/s rear arch where the filler cap would sit, my tank is inside
    9, Prep oe sideskirts and rear arches for re paint
    10, Weld in lots of little oe holes in engine bay (im after a cleaner look)
    11, Do some stitch welding in engine bay
    12, Relocate brake fluid reservoir into scuttle area ####
    13, Make an air filter box behind passenger headlight
    14, Prep engine bay, wheel arches, new sills etc for respray
    15, Mildly strip engine down and install piper 285 cam, springs etc (not going to happen till winter)
    16, Strip old paint and then re paint engine block (im thinking off using 2k, has anyone done this before)
    17, Paint gearbox with 2k paint
    18, Clean my carb as best as I can
    19, Put everything back
    20, Mot and drive the old girl
    21, Weld in a flexi/anti vibration exhaust pipe into my mid section (not sure what they are called)
    22, Put new valeo clutch on, probably get the flywheel cleaned/ resurfaced.
    Sorry for the long list but it will help spur me on, so whats on your to do list guys and gals.
    Re: An early whats left to do for FCS/national day
    Give it a clean, yep that's it. Saying that may just put some more new items on there when I get minute free.
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    1. Get a car working and legal
    2. That is all
    Apr 2011
    Netherlands
    Fab new nearside driveshaft
    Get tracking done/ fit other coilies
    Check brake system (goes soft after few drives over and over again)
    Make speedo drive work
    Make rev counter work
    Refabricate clutch system
    When k20 coils are working properly up the boost
    And maybe a quick clean (not realy into cleaning other then washing it now and then)
    Non-member JP Racing's Avatar
    Apr 2009
    Ely
    Plumb clutch in and bleed up
    Fit rad and hoses
    Fit chargecoolers and rad and hoses
    Sort fuel lines out
    Have my down pipe rewelded as it didnt quite clear the drive shaft bolts and finish my screamer pipe
    Oh and a clean and polish and fit some new flocked bits door cards and centre console
    Hopefully on the road mid april begining of may at the latest
    Apr 2011
    Netherlands
    so finished for ND then
    Apr 2009
    Ely
    Oh yes
    Apr 2011
    Netherlands
    lovely!
    Moderator
    South East Regional Rep
    LiamR's Avatar
    Dec 1998
    Medway, kent
    I need to MOT it, tax, insure and buy my FCS tickets...
    Plus work out how I will get my tent and everything else into the 5
    Feb 2011
    Carshalton, Surrey
    Just spotted this post, ND is now only 10 weeks away...
    my list involves basically rebuilding an entire GT Turbo from the bare shell
    Quote Originally Posted by Jeff Ninebar View Post
    Apr 2009
    Ely
    Plenty of time if you have nothing else to do
    Moderator Red October's Avatar
    Mar 2012
    Stoke on Shizzle
    New bonnet fit and re-spray
    Bumper, wings, grille and rear bumper re-spray.
    Inner arch modifications to take the wheel on full lock
    Full 3D map on the Nodiz to see how many ponies were running.
    Non-member Junglist's Avatar
    Dec 2008
    Chester
    Mot
    Tax
    Wash
    Possibly get some new front seats and anything else I can get from a 5GTT I've seen in someone's garden.
    Apr 2011
    Only 49 days left and I've still got a shed load off work to do. Hopefully I can tick off about 5 to do jobs come the end of next week. But for now I've just updated my original list at the start of this thread.
    Surely I'm not the only one with lots to do
    North West Area Rep LukeRobbo's Avatar
    Nov 2008
    Cumbria
    Im going down the easy route and taking my Honda :-)
    Apr 2011
    Netherlands
    Loads to do unfortunately
    Feb 2011
    Down South
    thats nasty arthur what happened??
    Apr 2011
    Ouch
    Non-member smithyr5gt's Avatar
    Mar 2013
    finish cleaning up engine bay.
    new water pump.
    campus pulley.
    clean car another 30 times.
    Apr 2011
    Netherlands
    Never ending problems with ignition caused me not to go to a rolling road to fiddle with the mapping. Testing top speed wothout monitoring anything didn't turn out to be a good idea
    Did manage to put 150 on the gps though before blue smoke came out of the exhaust. Don't worry though, it'll be at FCS/ND
    Feb 2012
    Nottingham
    I have a plan will do all I can if not I will be there in something else
    Ireland Co. Kilkenny
    when your over for the FCS arthur do your self a favour take your car to scoffs and get it mapped properly
    Apr 2011
    Netherlands
    I'm confident i can do it myself, problem just is i've been having all those problems with the fooking ignition! It really pisses me off, everything i make seems not to work as it's designed for while everyone else doesn't have problems.
    Same with the tacho output, i've set up everything as it should, checked everything over and over again and it just doesn't work....
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Quote Originally Posted by Slammed 66 View Post
    2. That is all
    Done. Another year for the phase 2 with no advisories on the test certificate
    Non-member scratcher's Avatar
    Milton Keynes - ish
    1. Find out when FCS/ND is
    2. Drill door hinges and fit shims (only had them for a few years)
    3. New number plates - already on order
    4. Heater matrix (been in the shed for maybe 4 years)
    5. MOT
    Buy a renault turbo,
    Fix the renault turbo (no doubt something will need doing),
    Find out when fcs is
    Non-member Goobie's Avatar
    Mar 2002
    East Sussex
    Looking for another 5 James?
    Feb 2011
    Down South
    its in the blood goobs, he may already have it hopefully pmsl
    Mar 2002
    East Sussex
    Spill the beans!
    Apr 2011
    Netherlands
    FCS is during your daughters birthday James!
    Feb 2011
    Down South
    Spill the beans!
    ill let jim tell ya
    but james could never be without, i told him so many times and i knew as soon as the mitzy was up for sale then he'd get another, but tbh james is a proper gent and im glad he's getting another as long as he don't change his mind or the seller pulls out pmsl
    good its STAYING in the club thou
    Spill the beans!
    just another tungy grey phase 2 of the forum its not perfect but picking it up tuesday late afternoon
    Lol she's end of june I may be ok if this is begining
    Apr 2011
    Netherlands
    I remember you telling me that, would be fun if you'd come! Romil is going to organize a convoy which we'll join
    Apr 2011
    That would be good
    Apr 2011
    Netherlands
    The 9 seems to be doing well so it's deffo making the cross over!
    Apr 2009
    Ely
    MOT tomorrow at 8. Took the car from my workshop, I say workshop it's a shed, to my house about a 15 mile drive it was damp out and raining. At 5 psi it's scary and went really well just got to turn the boost up now
