rear lights
At long last the car is getting somewhere now. im on my 3rd fuel pump after the other 2 seized up, and yes the fuel tank was cleaned while it was out. new brake lines put in (just need bleeding now). sunroof seal and glass all in after eventually finding the clips searching in scrapyards for months.
Now gotta start sorting out the electrics,
pas side rear light cluster, the top red light is fine until you start to indicate then the bulb dips and they flash (red and orange) together
any help..
Re: rear lights
Check your rear light earth wires, make sure its got a good contact on clean metal
Re: rear lights
splice into the black wire with a green strip, and make a new earth, then clean the tracks on the connector and the bit on the bulb holder that it goes onto
