just wandering how you remove the bottom parts of the rear seat. cant seem to work it out
are there any bolts to undo first
yeah i think the bottom 1s lift up and pull up out of the front slots! come2 think of it there maybe a couple of bolts on either side u may hav2 un-do... been a while since i took mine out. theres def bolts on 1 of em.
Nope just pull them up if your talking about the bottom part of the seat. only screw section is the back part which is on the floor. The bottom section is quite secure as it clips into a section but no bolts
thanks guys, a good tug should do the job then.
