Results 1 to 15 of 15
    Non-member bood's Avatar
    May 2011
    Blow off valve
    i am selling this or hoping to swap for a dump valve really.
    i removed this when plumbing in the front mount and now would like to go back to a dump valve as this is to tall for where i want it.
    it works great and makes a good loud noise and is in great condition.
    many thanks
    Adam
    Non-member westy94's Avatar
    Mar 2012
    Fareham
    Re: Blow off valve
    What's the difference between this and a dump valve then apart from the name ??????
    May 2011
    Re: Blow off valve
    i am not actually sure, it in theory is the same as a piston type dump valve i believe and obviously the single large outlet is diffent
    May 2011
    Re: Blow off valve
    Will be put on ebay tomorrow
    thanks
    Re: Blow off valve
    I have a bailey piston dump valve somewhere in garage.
    May 2011
    Re: Blow off valve
    I would be interested if its silver and in good condition
    Oct 2012
    A
    Re: Blow off valve
    All about a dump valve!
    Re: Blow off valve
    Search RTOC for piston d/v issues.
    Non-member dj_craig_'s Avatar
    May 2010
    Re: Blow off valve
    can you provide a link please mate ?
    Non-member Jonny5's Avatar
    Sleaford
    Re: Blow off valve
    Apr 2002
    Re: Blow off valve
    Quote Originally Posted by dj_craig_ View Post
    https://www.rtoc.org/boards/search.php
    May 2011
    Re: Blow off valve
    Well that's killed this thread
    i have run this on my car for 18 months no issues at all and if it wasn't for size it would be back on my car.
    I struggle to see how on could cause problems??? and it must be the same effect as the piston in the blow off valve
    I have done a quick title search and had no results.
    May 2010
    Re: Blow off valve
    Tryed that first and couldnt find a deffinative answer, hence the request.
    Re: Blow off valve
    There is no definitive answer. Some members supposedly use(d) piston d/v's for ages with no issue. However, a number of people have had Bailey d/v pistons stick open due to the residue in the boost air on a GTT building up and restricting its movement. This can potentially result in a lot of engine damage and has done for one or two.
    I swapped mine out for diaphragm version because of this reason. It looked, sounded and operated better. But that's just me.
    Oct 2012
    A
    Re: Blow off valve
    I've got a diaphragm one to fit, purely due to this rumour.
