Results 1 to 6 of 6
    Mar 2013
    afrs again
    right just put a t2 turbo back on with stock jets apart from 2nd stage drilled to 1.2mm was hitting 15 psi and afrs was around 13.1 so turned boost down to 1.3 psi and its still the same is this safe to keep like this or too lean ?
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    Re: afrs again
    Too lean.
    Mar 2013
    Re: afrs again
    how can i get it down abit
    Re: afrs again
    Try a 1.00mm A/C
    Mar 2013
    Re: afrs again
    ive got a 0.9 will that do ?
    Re: afrs again
    I suspect that'll make things a bit too rich. You could try it though. Or you could drill the 2nd stage out to 1.3 and re-check the AFR's then.
