alloy wheel fitment
Would wheels off a mk2 golf fit my 5? Cheers peeps
Re: alloy wheel fitment
If they are standard golf wheels the center bore is to small.
If they are aftermarket then they should be ok bore size.
Also long as they are 4x100 and depends on width and offset.
So that's a ling way of saying ...... dunno.
You need more info to be sure
Offset at ET35 and stud PCD are the same but bore is 57.1mm against the 5`s 60.1mm so alloys would need machining to suit
Ok cheers guys ill have to get him to check
