i need a os (uk drivers) door window motor if anyones got a working one around, i had 2 spare 1 both sides typically the ns works but wont fit thanx mick
Iirc the motor is the same and can just UN-clip and swap over to the over mechanism.
ill have a look thanx gaz, r u @ next surrey meet in bluey lol
I think where the motor connects to the mech on the mech part there is a circle made up of 3 or 4 clips if you lever them our the motor should pop off. Il have a look as I think I may have one somewhere anyway.
Got loads in stock if you are still in need of one.
Thanks MIke
Mick loosk like I was wrong I have found a motor here but it has n/s written on it the motors defo come off the mech tho but it looks like they may be sided as well as the mech its self.
no probs mate thought they were handed, ive pmed mike but no answer yet lol
anyone?? no answer from mike and cgb has none in gwo pleeeezeeee mikes dieing in this heat thanx mick
hopefully sorted ive bought one from dj so mike only needs to suffer until it comes and i put it in lol thanx again dj
if you get stuck mate got about 10
thanks Carlos
