Results 1 to 17 of 17
    Non-member mingblus3's Avatar
    Apr 2013
    Black R5 Bodykit Removal
    Thought it was about time I had a look behind the body kit seeing as its never been off the car, still has the original dimpled effect on the skirts. Have only taken one side off so far, cleaned up slightly and then kit back on until I have some more time.
    Quite pleased so far. Had a good dig around with the screw driver and found two spots that need attention straight away.
    I will remove the red paint from the calipers. Need some suggestion how to get that off?
    Non-member rs250nut's Avatar
    Re: Black R5 Bodykit Removal
    Shell from what you can see looks clean
    Norwich
    Looks really good considering what some are like with kit off! not much to worry about there then
    Apr 2013
    Got the other side off today. Same sort of thing. Will need minor repairs.
    Battery tray is also good underneath. Ill upload some pics later.
    Cheers
    Apr 2013
    Battery tray removed and cleaned up behind. The rusty mark on the original sealer is a water mark I think from rusty water laying in the corner.
    I will mask this out tomorrow and treat the bare metal area with some primer, Flat it back and then spray it over for the time being until the whole car gets done professionally.
    Non-member Goobie's Avatar
    Mar 2002
    East Sussex
    Quote Originally Posted by mingblus3 View Post
    Wire wheel if you got one, failing that, wire brush and a lot of patients.
    Apr 2013
    I've got a wire wheel. Didn't think to use that.
    Cheers.
    Non-member safehands's Avatar
    May 2013
    U lucky man see my thread lol
    Classifieds Moderator
    Mar 2004
    Use a wire wheel as said, angle grinder might be a bit dangerous in there so on a drill will be fine or a flappy sanding wheel..
    Wear safely glasses, I went hunting for rust on mine and was pulling wire out my face and clothes all the time.. You will lose an eye without.
    Treat the rust areas with something like Bilt Hamber rust eliminator to treat before any primer goes on.. I missed a few areas with the Bilt Hamber and the rust came straight through the etch primer.. I've since only got a coat of the treatment on without the primer and after a month or 2 it's still mint.
    Apr 2013
    I finally got everything removed from the car now for a good clean up. It's not going to need much and it's all original.
    Apr 2013
    I also had a scrape around in the inner wheel arch by the front sill to check for rust. Again all looks fresh. I guess there is no point removing it all.
    Non-member gttjames's Avatar
    Cambridge
    result
    Mine most definitely did not look like that......
    Norwich
    Really does look a good clean shell, definitely one of the better ones as seen ALOT worse!
    Mar 2002
    East Sussex
    Wow
    You got a beauty there with that shell! Always a lottery when removing the kit.
    Non-member Chris Beer's Avatar
    Plymouth, Devon
    Very Very JEALOUS
    Cambridge
    from the pics that shell does look like 1 of the best iv seen, lucky lad. Sort any little areas now and itl last for ages
