Results 1 to 44 of 44
    Mar 2013
    strange problems
    first off ive been having trouble with power going to starter i think just turn the key and complet dead just lights dim on dash ? and after taking car for a run this afternoon to see what afrs was reading foot down in 4th gear was 12.8 pulled up stoped car then wouldent start it turned over a few times but wouldent keep fireing i had my foot to the floor and it would hardley tick over then die....then started complet dead again iam baffled as where to start ive read a few things on here and checked them but still nothing
    Committee Member
    Social Media
    LeeR5GTT's Avatar
    Eat, Sleep, Boost
    Re: strange problems
    Quote Originally Posted by KEV 5 GT View Post
    my advice would be to get the bbq lit and some beers in the fridge and let some well experienced members pop round for a bit of a get together and take a look for you
    Mar 2013
    that sounds a good plan ive got some good bbq food in ready for when the sun comes out and a couple of creats off beer so if anyone wants to pop round and help me out your more than welcome
    Mar 2013
    bump....
    Norwich
    Is the starter motor sticking (solenoid) and making a clunk noise and dimming dash lights? mine does this, heard could be bad earth or wiring to the starter.
    The other problem sounds carb related, is the idle jet blocked? has it been rebuild/cleaned recently?
    Mar 2013
    ive put a new starter on it the other week i dont think theres any clicking but the dash lights go dim ? also not sure about whats been done to carb as ive not took it off or anythink to have a look
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    Sounds like a bad earth.
    The car probably wont restart due to you either flooding it ( mashing the pedal ) or the fuel evaporating. You have to learn the nack to getting them started.
    Mine is 3 full pedal pushes then feathered throttle.
    Mar 2013
    no when it did try and start it fired up then died like it was running on 1 cylinder or sommot
    Fuel pump relay or possibly fuel pump has failed, or you have ran out of fuel.
    Lack of starter is knackered wiring, do the 4 pin relay mod
    Mar 2013
    well i herd the fuel pump buzz after it cut out ? whats the starter mod ?
    Starter relay mod
    https://www.rtoc.org/boards/showthread.php?t=4724
    As for the engine not firing up - check for spark and fuel, basics first
    Mar 2013
    you dont think it could be the ignition switch at all ? as the key is stuck in it and i carnt seem to get it out ?
    Oct 2009
    Doncaster
    I would start with the fuel pump first.
    Mar 2013
    still having probs checked a few wires and relays today but got nothing to starter motor no clicking just dash lights dim ???
    Mar 2013
    bump
    Mar 2013
    pulling my hair out checked starter connections charged battery up and used another checked wiring + relays and still nothing to starter no click click or anything some body on here must be able to help me get her going again ????
    Dec 2011
    Have you tried bypassing realay by aei? . Have you got a multimetre
    Committee Member
    Social Media
    LeeR5GTT's Avatar
    Eat, Sleep, Boost
    if the lights are dim with a fully charge battery id be checking for a bad earth. make your own earth using a jump lead...
    Mar 2013
    yep ive done that mate looked and seached boards as well tryed a few trick but nothing puzzled me
    Mar 2013
    is that the relay at the aei with yellow wires i swaped these around with the the one at passenger head light
    Non-member Nick k's Avatar
    Leicester
    If your fuel pump is running when you crank, then you can rule out Aei module and that relay next to it + crank sensor. If you have a spark then the electric system is ok on that side of things.
    Mar 2013
    i dont think i can here fuel pump ifact i carnt here anything no buzzing no clicking not a thing as for spark it wont turn over so carnt check that
    Leicester
    Oh yea error... Lol. Ok when you fix the starter listen for the fuel pump
    Leicester
    You live in Leicester Kev, why didn't you say can pop around if needs be and have a butchers, I reckon if its electrical I'll fix it about 5 mins
    Take the starter motor off and test it.
    Mar 2013
    yh nick im in leicester mate where you from pm me mate
    Committee Member
    Social Media
    LeeR5GTT's Avatar
    Eat, Sleep, Boost
    Quote Originally Posted by Nick k View Post
    theres that rtoc love again
    Mar 2013
    Leicester
    The starter motor had Sh%t itself Kev's going to bolt another 1 on and see what happens.
    Tools used to trace fault :
    1 x multimeter
    1 x Hammer for that special solenoid/starter tap
    Mar 2013
    yh thanks nick nice to meet you and very much appreciate your help top bloke
    lets get that t25 on mate
    Mar 2013
    update on car put new starter motor on today that sorted that prob out but tryed starting it and no good it fired up a little but just pup pup pup and died....
    Mar 2013
    Just tryed starting car and chug chug chug and die ? I've checked fuel and that's coming thro and seems there's a spark at plugs so Iam now back to being baffled again
    Mar 2013
    bump......
    May 2013
    Have you checked all plugs for spark
    Mar 2013
    yh i checked plugs for spark mate not sure how strong the spark should be but dint seen very strong ? im pointing my finger at the aei at the min just wondering if its got owt to do with the rev limiter ive fitted ? could it of took the aei out damaged it or anything like that ?
    May 2013
    Try a sparkplug on the king lead see if its a different spark.
    Oct 2009
    Doncaster
    Remove the limiter for now - just to rule it out and try again. If it works then you have some supect wiring !
    Leicester
    Would like to book a revisit now the starter is fixed
    Mar 2013
    yes nick your more than welcome to pop round mate whens best for you ?
    Mar 2013
    well problem was down to rev limiter stopping car from starting does anyone know why this as hapened do revlimiters reset them selfs or you lot think its blew ?
  41. #41
    May 2013
    Was it wired right
  42. #42
    Mar 2013
    i wired it up from a diagram off here was ok for 2 weeks strange
  43. #43
    Non-member tubbyG's Avatar
    Dec 2010
    Faulty wiring (such as a damaged positive wire earthing on the chassis) would cause a signal being sent to the limiter via the earth.
    Did you remove all of the lmiter wires, or disconnect one at a time and attempt to start?
  44. #44
    Mar 2013
    i removed the red and blue the earth is still in place
