Results 1 to 8 of 8
    Nov 2010
    Adjusting GAZ Coilys?
    Hi everyone, just wondering if anyone could give me a bit of advice on how to raise my coilovers so I stop smashing my exhaust on everything! Is there a how to on here? Apologies it takes ages to browse the forum on my phone so if someone could link me it that would be much appreciated! Also what tools will I need? Thanks in advance
    Also should probably mention its a mk1 clio but using the GTT hubs, cheers.
    Non-member mightymanx's Avatar
    isle of man
    Re: Adjusting GAZ Coilys?
    is it just the front u want to adjust? if so just take the wheel off and give it a few turns exact diffrnce each side with the coil over spanner then see if its what height u want if not adjust a little more coil over spanners u can get off ebay
    Apr 2013
    Dublin
    Stupid question but if you want to raise the car do you turn the lever to the left or right?
    Dec 2004
    Aylesbury
    Raising the platform on the shock will raise the car, lowering the platform will lower car
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    I thought it worked the other way. Raising the platform, making the spring compress and therefore lowering the car.
    Ive got my gaz coilovers to set and fit when i get them collected.
    Is there a way to visually check a gaz unit to see if its a ph1 or ph2 unit?
    Feb 2009
    Walsall
    Adjusting it up so theres more thread showing at the bottom makes it higher, turning it down makes car lower
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Quote Originally Posted by w35ty View Post
    excellent.
    That should save me a bit of time when it comes to fitting mine then
    Nov 2010
    Thanks everyone, just ordered a pair of those spanners so just got to wait for them to be delivered now
