Hi guys, my steering seems to be able to move up and down and dosent feel very secure. Is there any way to tighten this up?
in and out or up, down, left, right?
Up and down, part of the dash moves too, when u free dude mite need you to come down and have a lool at the old tard for me.
little round steering column bush, steering wheel off hook it out, slide new one in refit wheel job done 10 mins
Will be doing this job on mine soon, am I right in thinking they are 2 bushes
Unless it's crumbled to bits, you won't be 'hooking it out', trust
I changed both bushes on Whitey's column a few months back, and both were a sod to remove.
Check the rod & u.j splines as well, and replace if the teeth look worn.
Can i get te bush from gsf? Or is it a dealer part only?
check the column is bolted to the car properly, there are two bolts at the top and a set of screws at the bottom that hold the dash in as well, the lower screws were missing on mine and the steering wheel moved up and down.
I have a column with a new top Bush fitted in if you want it £10.
When replacing mine, I screwed two long wide threaded screws in either side of the column shaft, spray some wd40 in the tube section then got the mole grips on the screws and pulled it out!
Orderd from renault, special order from france so should be with me on friday. Then ill let the fun begin!!
https://www.rtoc.org/boards/showthread.php?t=4731
Pictures lost unfortunately
Right now im confused! Is there two bushes i need to replace or just 1 is the bottom bush the UJ bush
Another ignored post...
2 bushes mate, 1 at the top and 1 at the bottom if the column. Worth checking the UJ also.....
pease of piss to get out. but only i knows how. hint use the stearing shaft to bash the bushes out
Dainty who? I'm a geeza; wouldn't be seen dead in a shop with a name like that...
I thought that was you, but wasn't sure, hence the double-take & intrigued look Even said to Bekki I'm sure that's Matt from the club, but didn't want to look a pillock by saying hello & it wasn't you.
Was you wedding shopping as well?
Tell me about it! I should have shares in the place, the amount of times we've visited it in the past 6 months.
Should we bump into each other again, I'll defo say hello
