Results 1 to 5 of 5
    Non-member Wallace's Avatar
    herts
    Clarke MIG 151TE Welder - Cheshunt
    Bought to do the sills on my car, in EXCELLENT CONDITION – includes instructions, a can of anti-splatter spray and CO2 gas canister (unsure of how much is left so just assume will need to buy another also), the copper reel has loads left on it!
    I would like £250 Collected - will post but will agree costings first as its big & heavy!
    Little Bit of the spec:
    CLARKE 151TE 230V 13A PLUG GAS BOTTLE 130AMP TURBO MIG WELDER
    The fan cooled turbo unit has the following MIG welding capacity:
    Maximum amperage: 130amps - Amperage at 60% duty: 57amps - Min amperage: 30amps
    Open circuit voltage: 18 / 26
    Input voltage: 230v
    Wheels: yes
    Power settings from 30 to 130amps.
    Welds mild steel up to 5mm thick.
    Turbo fan cooling for improved duty cycle & transformer life.
    Welding wire 0.6 and 0.8mm wire up to 5kg spool.
    Fully variable electronic wire speed control.
    Operates from 230v, single phase power supply.
    Thermal overload protection with auto reset.
    Weight: 29kg + packaging
    Dimensions: maximum length 700mm - maximum width 320mm - maximum height 580mm
    herts
    Re: Clarke MIG 151TE Welder - Cheshunt
    Bump
    burton on trent
    same welder i use.. every1 comments on how good it is for a small welder..
    glws
    herts
    glws
    herts
    Any takers @ £230 DELIVERED????
    And there is a welding mask with it, just forgot to add that info
