gtt king lead
Looking for a gtt king lead pref silicone 7 or 8mm jobbie.
Re: gtt king lead
I have a full set of 7mm leads for sale, red including the king lead if you need mate
Re: gtt king lead
Only king lead needed, c1j ht leads wont reach.
Committee, Treasurer, Memberships admin
Re: gtt king lead
I have spare a king lead. It's silicone but thinner and black. Not branded, IIRC. I'll have a look at the length. Won't need much £ for it.
Re: gtt king lead
C1j King lead will defo be long enough but really looking for a nice thick lead as I have a thick set of ht leads to go on.
Re: gtt king lead
It's 7mm thick and 85 cm length.
[IMG][/IMG][IMG][/IMG]
Re: gtt king lead
7mm that's plenty thick enough that looks perfect matey how much? Just to be sure the dizzy end fitting is the internal type fitting and not one like a spark plug? If that makes sense
Re: gtt king lead
The one on the right in the photo is the Disty end, 90° bend, plugs into the recess in the disty.
The straight end goes onto the 'spark plug' coil terminal.
90g grams in the envelop. 2nd class is £2.20. Recorded is £3.15.
£5 + post?
Re: gtt king lead
The 90's on the dizzy end don't think that will work matey. I need the internal fitting for a b18ft coil but it is very deep, the last lead was like this and I had to bend it straight after a few times of taking it off it snapped
Re: gtt king lead
I took the boots off to see if they would swap. No. The bent end doesn't straighten and the straight end doesn't bend.
There might be some new ends available though......
Re: gtt king lead
Shame as it looks like a decent lead, cheers for trying tho matey but I think il just have the same problem as I've been having
Re: gtt king lead
I found an ebay seller with 36,000 items listed who might sell the appropriate ends. I've asked a question to see if he can point me to them.
Re: gtt king lead
That's what I have now decided to do. Just bought the end that I need and I will fit it to the old lead and see how that goes.
