Results 1 to 10 of 10
    Non-member Kenobi's Avatar
    Jul 2006
    Leicestershire
    OIL leak 5 GT turbo
    the oil is dripping off the base of my sump but its running dow the right hand side of the sump. (passenger side of it)
    Whats that then? MarkyMark just explained it to me on the phone. However it all went over my head as im thick.
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: OIL leak 5 GT turbo
    Could be from numerous points - Crank seal, turbo return pipe on sump, turbo feed/pressure sender/non-return valve, oil level sender, from the cover where the mechanical fuel pump would go, oil cooler pipes, rocker cover gasket...
    Wirral
    Could be the crankshaft oil seal is leaking .........or maybe its the half moon sump seal on that side .... best hope for sump seal
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    give it all a good wipe and try and locate it better
    Member D4WNO's Avatar
    Jul 2004
    London
    Moving this to the 5 GTT forum, the clue is in the name Kenobi lol
    It might be leaking further up from the sump. From my own experience rocker covers like a good ol' leak and as Mart mentioned the oil return pipe common culprit.
    Have a good clean and check before you go pulling the Sump off.
    Jul 2006
    Leicestershire
    Quote Originally Posted by V Man View Post
    I gave it a wipe down went for a drive and came back.
    Its deffo on the right where the oil is coming from. i Think it may be coming from where the oil sender wires are. Christ I know im hard work. does that make any sense to anyone.
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Quote Originally Posted by Kenobi View Post
    exactly where mine is leaking from, infact i havent figured it out 100% yet.
    ive - fitted a new oil sensor with a new copper washer , replaced the rubber oil return pipe , replaced the copper washers on the turbo oil feed where it bolts to the block..... and its still leaking from somewhere around here
    im just glad as i know its not coming from the crank seal or the half moon as them areas are oil free.
    Dec 2004
    Aylesbury
    Thats makes abit more sense mate That shouldn't be too bad to do, prob be the pressure switch or the oil return hose
    Jul 2006
    Leicestershire
    Ah cool.
