I need the part numbers for the two oil return o rings(male end that fits into block) and a water pump thermostat(prob same as clio 172/182).
Ta
Ta
BUMP
If anyone knows the renault dialogy vehicle type for the megane 2.0 16v turbo i can have a look for you matey on my dialogy software.
The clio is CB0N for the 172
Thermostat for 172 is - 77 00 872 554 THERMOSTAT about £16.05 89degree marking
The only megane codes I have got are
Megane
BAOE - Megane hatch 1.4 RT
BA0F - Megane hatch 1.6
BA08 - Megane hatch 1.9 DTI
EA0H - Megane Coupe/Cabriolet 2.0 16V
BA0H - Megane 2.0 16V
Megane Coupe ph1 1996-1999
DAOF 1.6
DAOG 2.0 8v
DAOH 2.0 16v
DAON 1.9Dti
the clio is F4R 730
What is the megane engine is it an F4R ???
I could be able to find out another way
megane RS is CM2H96, not sure if thats the same. engine is F4R774
Aye 225 and 172 are the same thermostat!!
Thanks chaps! Once again very helpfull!
