I took my five out for a bit of cold air fun tonight, seemed to go a bit better now the temps have dropped somewhat
Anyway after blowing a boost hose that almost sits behind the front bumper and spending half an hour in a tesco car park trying to put it back on and clip it up good and proper whist being aksed by the local youth the ususal questions
How much boost do you run?
What sort of power does it pull?
Does it have a dump valve?
Have you ever blown a head gasket?
And such like.
I have been having a wiring issue for a while now and i need to get to the bottom of it before i end up ringing the AA one evening.
When i turn on the ignition i get no battery light on the dash, it doesnt light up once the engine is running either, so i'm worried that my alt isnt charging the battery because if the light doesnt come on when the ignition is turned on I'm lead to belive this means the alt isnt connected to the battery.
It made it home anyway but i think the issue lies in the connerctor of doom, if i play with said connector sometimes the battery light comes on then sometimes it turns off.
As the haynes wiring diagrams are like some kind of long lost ancient code to me, does anybody know what wires i should be looking at in said connector that run to the alternator?
Obviosly i need to check if the battery is actually charging or not with a multi meter when i get chance.
The car appeared to run fine for the 10 miles or so on the way home but the battery is a suoer duper strong one so that might have something to do with it running ok for a short while.
