Results 1 to 14 of 14
    Non-member Pete@Backyard Racing's Avatar
    Nov 2008
    Manchester
    R5 gtx front engine mount
    R5 gtx front engine mount (metal bracket not rubber part)
    Cash waiting or px for r5 parts
    Nov 2008
    Manchester
    Re: R5 gtx front engine mount
    Anyone got one of these??
    Quote Originally Posted by Pete@Backyard Racing View Post
    Mike will prob be your best bet but you can always drill out the C1J one to fit the F series / b18 engine if that's what you doing
    Jul 2009
    lost
    non existant from renault now. the only thing i have is the rubber mount if its any good? brand new in packet.
    Nov 2008
    Manchester
    Mike has only got one that he's replicating. I might just end up drilling the c1j mount to fit. Is the c1j rubber the same as the gtx rubber??
    Yeah rubbers the same
    Nov 2008
    Manchester
    I thought so, was just checking. Thanks
    Trader
    Nocturnal Developments
    Haz's Avatar
    I think the rubbers different, you can use a gtt mount but its not quite the same angle so squashes the rubber more on one side
    Jul 2009
    lost
    Quote Originally Posted by Haz View Post
    spot on haz the rubber mounts cant be brought from renault anymore either. they come back as standard 5 mounts
    Rubbers are defo the same, I bought GTX mount and rubbers when I done the f7p conversion new from renault and the rubber was the same as C1J metal mount's different
    Jul 2009
    lost
    it shouldnt be buddy. i will try sort a pic out of a standard one and the gtx one. wont be easy as its in a packet
    Quote Originally Posted by r5_scotty View Post
    they are GTX rubber is same as gtt the metal mounts are different
    (pic of gtx rubber and GTx mount, I have had it side by side with gtt rubber and they are identical).
    Why should the rubbers be different?? its the metal bracket that holds the engine differently not the rubber mount I have done the conversion's a few times now and metal mount is the only difference
    Trader
    Haz's Avatar
    The rubbers should be different as the f block weighs more, and the angle of the mount is taller on one side. If you have one from Renault thats the same it's because it is a gtt not gtx and they have just listed them for both types as out of stock vans and clios with the gtx mount are the same too, so long as they are 1.7's. The 1.8 versions are different again.
    Jul 2009
    lost
    if im right im sure on the rubber gtx mout the back metal plate which attaches to the metal mount has more of and angle. the mount photoed defently looks like a gtt one
