Re: A few pointers please??
Change the fuel filter and check the boost reference pipe to the fprforsplits.
I would check the spark plugs, with a grp A carb fitted (which i would recommend removing) it would be fueling fairly rich on idle and part throttle driving so might have sooted up the plugs
ive had plugs out an given them a clean,topped fuel tank up an given another run i suspect my boost gauge isnt reading right. Ive closed off adjustable valve an it seems to boost less an the misfire/hesitation isnt there wind it out an it comes back although the boost gauge only ever varies between 8-10psi(depending on adjustable boost position) vacuum pipe to fpr looks ok.Got a new fuel filter to fit tomo. i would love to stick a standard carb on it just got various other issues to sort first unless i can find one at a decent price????
Thanks for help lads
