As wrote above, will they fit the r5gt? I read somewhere in here that it can be done, but is any modification involved?
Got 15" rims atm too.
Checked eflay and they are at very good prices, i mean wth they are brembos 4 pots!
Do you know if this would be the same for a 19 16v Finch? I have been looking at this conversion for my cabriolet. Didn't really know about the spacing untill you have mentioned. I am running a set of 18in Khans, and was going to run the 406 caliper with a megane grand scenic disc (300x24), the 406 runs a 305x28 IIRC.
Is the spacing you mentioned only due to running 15's on a 5?
wow nice! Ty for the answer mate, when u say 5mm washers u mean in diameter or in width. If u mean like those on photo they must be 1-2mm in width?
Also about the hubcentrics these go OVER the discs and behind the wheels, right? IOf that's the case it will have bonus AWSOME looks too
Great. So something like this? Althouth these don't have the centre, whells are secured by bolts only.
http://viewitem.eim.ebay.gr/Alloy-wh...889963835/item
ok so i need some more opinions on he matter please. Had a convo today about the 30mm hubcentrics with a qualified wheel engineer and told me it would be way to big and i would have problems with the wings arches etc.Plus +6cm total incrase it's immense. Most i should put is 2cm each side.
So the question is, has anyone did it before and can tell me if he had any issues with 15" wheels, the wings etc. Also the 30mm hubcentrics are needed cause of the wheels being 15"? Meaning if i put some 16" wheels will i not need them or at least so big?
You need the 30mm hubcentric be it on a 15" wheel, 16" 17" etc, but saying that you may need noeed 30mm as it will depend on your alloy ET the 30mm is based on std ET fitment the hubcentric's are there to space out the wheel due to the size of the Brembo caliper, again this could also depend on your alloy ET anyway.
I had the brembo's on a slammed clio and a few peeps now have them on 5's, on the clio ok it's slightly wider than the 5 there was no clearance issue's and the car was proper slammed. Again depending how low your car is I can't see there being an issue catching the front wing unless your car is seriously slammed.
No not extremely lowered now, just some basic 3cm i guess, i have clearance and stuff. What i was thinking is when more people get in it gets a bit lower so maybe then it's the problem :P
Any other bigger and better brakes that i can use? Damn the brembos are at a great price but if i can't have a second person inside!
Dont forget to fit a bigger master cylinder to match.
OK, after a quick conversation with the wheel expert again, he informed me that the oe wheel is 5.5J but the ones i got are 7J, so he thinks i shouldn't put 3cm hubcentrics, most probably at about 1cm. Anyone can confirm?
the brembos wont fit with the o.e 13" speedline wheels. whats so wrong with the 30mm spacers?
Haha, no i didn't mean that. Above we were saying that on oe readings u need to put a 30mm hubcentrics for the calipers to fit.Ofc on a 15" wheel at least.But on OE readings wheels are 5.5J while the ones i got now are 7J.
Could the calipers be made to work on a 172/182? They have 280mm discs
The discs that are used are the clio 172 / 182 jobs anyway if the caliper mountint points are the same as the gtt and the valver then yes. In fact i think schwartz runs 172 calipers and discs on his gtt hubs. I reckon they would fit again using the hubcentrics dependant on your wheel et as to what size hubcentric spacer
et measurement? Isn't the wider the J number on wheels, the more "out" they are? As things go i see that i will have to buy the brembos first then just ssee whats nedded on the hub :P
ET / offset. You just need to make sure you have sifficent space between caliper and the inner wheel
