renault 5 window motors
jus wonderin if u can still buy new windows motors, ive took mine off wired it to a battery and it works but there obviously no weight on it. is it the motors wat go lazy or is it common for them too lose feed ,
Super Administrator
Re: renault 5 window motors
Generally if there slow its the regulator not motor if motor is working 9 times its the regulator you can get them 2nd hand from mike at gt turbo spares boss
it only goes down now and not up lol
Super Administrator
If it goes up but slow sounds like regulator mate it has a cog on motor so if it goes down it should go up but maybe slow, I've just done one thought it was motor turned out to be the regulator mate
Super Administrator
Ps swap console window switches wiv each other to just to make sure it's not that faulty
Yes can still source they are £230 a side, motor with reg.
loads of wd40 sprayed into the brushes....usually works....
