Finally got new clutch for car. http://s1171.photobucket.com/albums/...t=56b9b311.jpg
hope thats the right picture, i had to edit your link so it worked.
Twin plate nice.
Hopefully this one will work
I tried one of these once and it failed on the clutch relese arm had to take it all back out and fit a single plate 7 1/4".. Mine was tilton though, so hopefully yours is slimmer being as it's ap..
I spose I could of got round it by going hydrolic release bearing, but, that would of been more ball ache lol
Sounds good mate.. Just make sure before you go bolting it all in (like I did ) then think, oow I better try turning it over before I go too far
I was also restricted on how much I could take out the fly wheel (due to standard TDC pick up) shouldn't be a problem for you, if run the Scoff trigger wheel??
is the standard fit helix just slipping then? wouldn't an oversize 215mm megane 6 paddle of done it?
yeah I guess its a risk with the laughing gas on the go as well
what clutch does Rob run in the F7P?
plus it looks trick as fcuk
Glad your getting sorted Glen. Tried AP, Helix, Mardi Gras and others to get a decent clutch for the NDO box, but feck all rated over 385ft/lb!
