Results 1 to 11 of 11
    Mar 2011
    Beaconsfield
    5th gear at 1000rpm - what speed?
    Does anybody know this, on a standard car, standard 13" wheels and tyre combo?
    Non-member SirSamuelOfBuca's Avatar
    Jan 2012
    Whittington
    Re: 5th gear at 1000rpm - what speed?
    i duno but i know there is a calculator about ill see if i can find it for you
    Jan 2012
    Whittington
    I cannot find it
    http://membres.multimania.fr/r5gt/gtt/trick9.htm
    might be on there but cant remember.
    Dec 2011
    Quote Originally Posted by SirSamuelOfBuca View Post
    I cannot find it
    https://www.rtoc.org/files/index.php?...20Calculation/
    Here you go, big thanks to Bigfoot
    Mar 2011
    Beaconsfield
    3210rpm is 70mph on standard set up (tyres wheels etc).
    Does this sound right?
    Non-member SCHWARTZ's Avatar
    Wallington south london
    1000 rpm i would say is about 25mph depends on if your going by gauge or gps as gauges are allways miles out. my speed O is around 10mph out i have to do 3600 to get the needle to 70
    Non-member Logg's Avatar
    my five is like that on 185/50/14 tyres. Just changed the final drive to the Renault 11 one on Dales excel sheet and it lines up perfect with my gps speed and rev counter. So guess that means I have a 11 box in mine. :'( too short for me.
    i have 195/45/15's i think that works out to the same as standard
    Dec 2011
    I read a post once that said "195/45/15's have the same rolling diameter as a standard tyre"...
    Not sure how true this is as my speedo does not match the GPS, but the chart matches the GPS, i.e. at 3250 revs i'm doing 72mpm(ish) - I have 195/45/15's
    Quote Originally Posted by Romil Davda View Post
    Il take mine for a blast later with the GPS and see how mine turns out.
