Results 1 to 14 of 14
    norwich
    5 / clio dials?
    hi,
    just wondering if somebody could tell me if the clocks from the clio are the same as the 5, obviously they will not have a boost gauge incorperated in the rev counter, will they be a straight swap or are the connectors different?
    tia
    nick
    Non-member rs250nut's Avatar
    Re: 5 / clio dials?
    I know the clio williams has a cable for the speedo where as the five is electronic
    Non-member markey b's Avatar
    Bury St Edmunds
    Re: 5 / clio dials?
    the fixings are slightly different, however i think you can swap the plastic faces
    Re: 5 / clio dials?
    I have clio 1.4 rt dials in mine at the moment till I sort out swapping them for a set from the williams.
    norwich
    Re: 5 / clio dials?
    cheers guys, the reason being the white dials have now turned more of a yellow colour, was told about a clio being broken and was gonna have the dials but didn't want to buy them if they wouldn't fit
    Re: 5 / clio dials?
    Quote Originally Posted by tricky nicky View Post
    You not running a GT Turbo box then?
    Bury St Edmunds
    Re: 5 / clio dials?
    get a brand new set of lockwoods from the bay for abou £20.... bargain
    norwich
    Re: 5 / clio dials?
    sorry, probably didn't make myself clear there, wanted to replace my 5 gt turbo dials with clio 16v dials . so now under the impression the gt turbo box and clocks are electronic and clio is a mechanical set up, so not a straight swap
    Dec 2004
    Aylesbury
    Re: 5 / clio dials?
    Correct mate
    Bury St Edmunds
    Re: 5 / clio dials?
    also, the digital fuel gage wont work i'd imagine..
    Re: 5 / clio dials?
    Only some of the 16v clocks came with digital guage. Also you would need to swap over 2 of the lights as they are the other way round. Cant remember which ones though without looking.
    Non-member mr white's Avatar
    bromley
    Re: 5 / clio dials?
    dale could you find out what lights need swaping on the clio 16v dials for me please as i putting the clocks in tyhe 5 tomorrow. hopefully will will be firing up the f7p in the 5 tomorrow
    Re: 5 / clio dials?
    Ill see what I can do tomorrow night, need to go outside to the cars to take some pictures so should be able to work it out then.
    bromley
    Re: 5 / clio dials?
    sweet
