Results 1 to 10 of 10
    Feb 2012
    uphall west lothian
    speedo stopped moving
    Hi people I'm new to renault 5s and my speedo has stopped working, sometimes its fine and others it doesn't move at all, all the other gauges seam to be working fine though, has anyone got any ideas
    Dec 2004
    Aylesbury
    Re: speedo stopped moving
    Remove the clocks and check the connection behind and make sure its nice and clean, also the join in the engine bay make syre thats ok too. Its a black cylinder connector which lives near the passenger suspension turret
    Feb 2012
    uphall west lothian
    how easy is it to remove the clocks, will give this a try tomorrow as I'm off, also thanks for the quick reply
    Non-member SirSamuelOfBuca's Avatar
    Jan 2012
    Whittington
    I'd check the wire. Mine melted on the exhaust. It comes out of the bulk head and is white and attaches to the lower part. The lower is the one most likely damaged.
    Nov 2011
    clocks are easy to remove, the plastic shelf looking thing above the instument panel just slides up, and i think the instument panel is held on by two screws. DON'T DIG A SCREW DRIVER UNDER THE INSTUMENT PANEL, just be gental and it comes out easy enough.
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    be a good idea to remove the connector on passenger turret and put another one on there,you can get just do it with block connectors or twist the wires together then tape up or use flashy super sleeve's.
    Non-member adscan's Avatar
    Apr 2011
    Mine went the same way. Replaced the top speedo cable and all was well again.
    Feb 2012
    uphall west lothian
    Where is the best place to buy a replacement top part for the speedo cable and I'll give that a try, this is my first old car, my wife and about 10 others are waiting to tell me "I told you so" but I always wanted a 5 turbo when I was younger lol
    Non-member Gibbo69's Avatar
    Jan 2011
    Quote Originally Posted by cook1981 View Post
    Before you go out and buy a new cable & disconnecting the clocks ect ... As the guys have said there is grey cable with a black connection by the passanger suspension turret .... Disconnect it & get a wire brush on the 3 prong connectors ... Bit of WD40 and I may just do the trick works with mine everytime
    Gibbo
    Feb 2012
    uphall west lothian
    Thanks folks speedo working again, while I was at it I replaced the tatty phase 2 rear door card with phase 1 ones makes such a difference and they shine up great with flash dash
