Results 1 to 8 of 8
    Feb 2012
    my r5turbo
    [IMG]http://i1100.photobucket.com/albums/g409/animal03/fb8e72a7.jpg[/IMG
    will put some more on when i get chance
    Non-member LYNCHSTAR's Avatar
    Re: my r5turbo
    I would be moving that induction kit you would be getting a lot of heat soak from turbo cut the telephone hose so its a 90 deg bend and put filter on so air comes through intercooler it would be a lot better. correct me if im wrong but has the car got a manual fan switch i can see some wireing there if so put it back to normal.
    Feb 2012
    Re: my r5turbo
    Dont get what u mean mate about telephone hose?and the bend of the turbo?
    Norwich
    Re: my r5turbo
    Telephone hose is the one that goes from the air filter to the front of the turbo, looks a bit like old school telephone. If you dont cut it, basically it means that the airfilter will sit right next to the turbo which will be red hot and cause hot air to be sucked into turbo (heatsoak). If you cut it at 90 degrees (in middle) it will allow air filter to sit longways in engine bay and therefore across the back of the intercooler for less heatsoak so it gets more cold air. I have mine like this, also would recommend running a heatshield to save wires, hoses etc getting hot/melted from turbo
    Feb 2012
    Re: my r5turbo
    Is there any chance u can send me a pic showing me cause I don't want to mess it up
    Non-member HendyR5's Avatar
    Mar 2010
    Ardrossan
    Re: my r5turbo
    Quote Originally Posted by Bainesy01 View Post
    Heres one for u bainesy.... http://www.gt-turbo-spares.co.uk/car...ts&prod_id=229
    Feb 2012
    Re: my r5turbo
    Cheers I know which one u mean now so just make it a 90"bend and then closer to the inter cooler? If so easy to do int it
    Mar 2010
    Ardrossan
    Re: my r5turbo
    Pretty much mate, so ur air filter points towards the wing. A had to move my coolant slighty to fit the filter in beside it! Yip mate very easy to do.
