Page 1 of 2 12 LastLast
Results 1 to 50 of 61
    South Wales
    B2GTT - My Black R5 Gt Turbo 1990
    Should have done this a while ago hers how my 1990 renault 5 has changed over the last few years
    Stainless steel laser cut dial surround
    Stainless steel boot catch
    Stainless steel battery tray
    New Lightweight bonnet vented and painted
    Dials fitted into dash
    Stainless steel heater surround
    Old steering wheel
    New boss fitted
    New wheel fitted
    Shot from outside the car
    Old downpipe and new enlarged one
    New exhaust
    Big brake conversion fitted
    Avo coilovers fitted
    Car failed the mot on rust on the sill this was patched up and side skirt re fitted and bleded back into car
    Car being stripped to fit sound system and black raider carpet
    Old gearstick
    Short shift fitted
    New red gear gaitor and gt tuning handbrake handle
    Car being cleaned up ready for trax
    South Wales
    Re: B2GTT - My Black R5 Gt Turbo 1990
    Shots of the car taken by a photographer at a local car cruise
    South Wales
    Full leather interior fitted
    How the engine used to look
    Full stainless steel larger bore exhaust fitted
    South Wales
    Wishbones fitted with super flex bushes
    old bushes burnt out with a blow torch
    New bushes fitted into place
    South Wales
    Rebuilt carb supplied and fitted by Tony (fishead) also fueling setup and in car boost removed
    South Wales
    A few shots of the car with the 15" on
    South Wales
    New anti roll bar bushes fitted
    15" wheels sprayed black
    South Wales
    Plenty more to come the car was sent down to fishead in july and had the following will get the pictures up when I get them from him and mike a.k.a phase 1
    *Engine out
    *Engine bay sprayed
    *New loom
    *New clutch
    *New lightened and balanced flywheel
    *Alloy rad
    *Ktec front mount intercooler
    *Raceland tubular manifold
    *New engine mounts
    *All engine brackets powder coated black by my friend
    *Mocal oil cooler
    *Spal fan
    *Piper 285 complete cam kit
    *Rebuilt turbo
    *Scoff e.f.i trigger wheel and sensor
    *Aem tru boost thanks to james 5 cheers mate
    *Fueling set back up
    South Wales
    Lil update im still waiting for pictures of the engine being put together and the bay being sprayed
    I took the car for mot and it failed big time on the sills so it was time to get them done properly
    pictures from one the side skirts was removed
    Passenger side
    Drivers side
    South Wales
    This is the latest pics of the car away having the jacking points replaced and new inner and outer sills fitted
    Non-member benj88's Avatar
    Mar 2010
    Re: B2GTT - My Back R5 Gt Turbo 1990
    Sure this was featured in rev's years ago?
    South Wales
    Quote Originally Posted by benj88 View Post
    Yea thats true I had it not long after
    Non-member adscan's Avatar
    Apr 2011
    how much for the jacking points and sills to be fitted? mine will need the jacking points replaced soon. what should this cost?
    cheers
    Aug 2004
    Quote Originally Posted by adscan View Post
    cheers
    Would you supplly the parts?
    Sills & Jacking points are around £200
    Fitting £200-£400 depending on where you go & other bits that need doing.. also Inner sills may need doing...
    Apr 2011
    Quote Originally Posted by Penfold aka The Dealer View Post
    sills are okay. just soft on the front corners. where are you guys getting your metal from? mike or CGB? i will be supplying the parts. can most body shops do this or is it a job for a renault specialist?
    sorry for thread hijack.
    Aug 2004
    A Decent bodyshop / welder should be able to do the job...
    Mike is better price & service than CGB...
    South Wales
    I got my jacking points from mike and inner sill repair panels from ashy On here
    I don't know anything about welding or bodywork so do you guys think the sills repair work looks ok?
    Apr 2011
    Quote Originally Posted by Danboi2 View Post
    how much are you paying for the welding/sill repairs?
    i am trying to workout what i should be paying.
    repairs are looking top by the way..
    ta
    South Wales
    I paid £480 and that was me supplying the parts then it was extra for the repair panel for the floor and for the sills to be sprayed and car undersealed.
    Probably could have had it done cheaper but car was off the road because of it failing its mot because of the sills and the tax was out! The guy who done came out to the house to give me a quote also give me trade plate to get the car there and back and let me pay in installments
    Apr 2011
    wow thats a pretty good service!
    i am in a similar situation..my MOT is out and i know it will fail on the front jacking points. i have popped into a body shop near my house to ask about repairs and prices. as the MOT is out it is not as simple as just getting the car to them and up on the ramps.
    what i will probably do is book an MOT and get a better idea on exactly what welding / repairs it will need to pass and then take it straight round to the body shop to get it priced.
    talking to them they seem okay.. without seeing it they said it would be around £150 a side to do the jacking points.
    how long are your repairs going to take? did your side skirts and arches come off okay?
    South Wales
    Cars back with me now it took about 7/8 weeks but that was over Christmas/new years/ bad weather with the snow
    The rear arches seemed to come off ok and as for the side skirts I had ktec racing combat side skirts on I am planning on putting some oe side skirts back on and changing the rear arches. When I can find good parts to replace with
    South Wales
    little update I got some used front arches rear arches and side skirts gonna get them sprayed up and fitted
    Front and rear arches theres only one rear arch as i managed to pick up one the same color as my car from mike at gt turbo spares
    Side skirts
    side skirts need some work with the fingers lugs and the usual places
    South Wales
    Received my box of parts from mike at gt turbo spares this morning
    Also picked up some brand new parts from renault 2 brand new front wings and a grill badge
    South Wales
    Parts all sprayed up and repaired
    The car will be off to the sprayer soon to have these fitted hopefully in time for the guildford fete day
    South Wales
    Interior stripped out to give a good clean and paint
    Cleaned and degrease using por 15 marine clean and metal ready then on with the por 15 rust treatment
    Half done
    all finished and left to dry which took about 15 mins
    South Wales
    Car in its new home
    Arches removed
    New arches trial fitted
    Drivers side rear arch removed to reveal some rust
    South Wales
    Bumper removed
    Managed to get the rear bumper off and the bumper support brackets fell apart
    Oe Rear bumper trial fitted
    South Wales
    Car has now been dropped off at the bodyshop to have the following done
    Weld in two bumper support brackets
    Paint backend beneath bumper including new bumper brackets
    Repair scratch in rear quarter panel and cut out rust patch
    Fit new brass door insets and torx bolts
    Allign doors up
    Fit freshly painted new wings and arches
    Have dents taken out of the doors
    Fit side skirts
    Remove ktec roof spoiler weld any holes underneath
    Fit oe spoiler once I get some clips and tape
    Classifieds Moderator
    Mar 2004
    Good stuff. Some hard work and ££ being chucked into this, should be worth it in the end, a good solid gtt that will last years and years..
    South Wales
    Thanks alot its going to look so different with the new arches side skirts and oe rear spoiler on! Hopefully it will be ready for national day
    South Wales
    Rear bumper brackets
    Bodyshop is rammed atm so dont look like my car will be done in time for the renault festival at the end of the month
    South Wales
    Uploaded with ImageShack.us
    South Wales
    Looks so much better now you have ditched the bodykit
    South Wales
    Cheers mate sideskirts aint fitted right though so might need some advice on putting them back on properly
    Feb 2012
    Nottingham
    Bet it's quicker too
    South Wales
    at least it wont be like a snow plow in the winter with the ktec front bumper on haha
    South Wales
    Had my engine rebuilt by a member on here fishead
    https://www.rtoc.org/boards/member.php?u=252
    Heres what was done
    Remove engine and gearbox. Strip clean and paint engine and box. fit piper 285 performance camshaft kit inc uprated valve springs, and vernier timing gear. Fit tubular exhaust manifold, hybrid turbo, lightened flywheel, uprated clutch kit, new engine wiring loom, front mount intercooler kit, oil cooler kit, performance air intake, engine breather catch tank, uprated cooling fan assembly and other supplied cosmetically enhancing products. Fitting of supplied efi related sensors ready for future efi conversion
    Fit new front bumper inc modifying of all related components to incorporate large intercooler, fit and set up supplied AEM TRU Boost electronic boost controller.
    Strip, clean, prep and paint engine bay front bumper and bonnet to requested ‘show’ std.
    Install full cosmetically refreshed unit to highest visually appealing std testing for fit, function and security
    Full on road ‘live’ set up of boost controller and carburettor fuelling requirements
    removed power unit from vehicle, removed fixings ect from engine bay, degreased and chemically cleaned, prepared engine bay ready for transport to body shop.
    Degreased and chemically cleaned power unit ready for work. striped engine/box of all ancillaries wiring ect and sealed units. C/o further chemical cleaning preparation for painting. Removed cylinder head, oil sump, timing cover and 5"‘ gear cover. Painted engine/box all covers brackets and all related parts in requested colours with suitable oil resistant products.
    c/o cylinder head inspection, stripped engine bottom end ’n preparation for performance camshaft fitment.
    Fully stripped engine down, components sent to engineer for machining. Engine block internally cleaned and prepared for rebuild inc all internal oil/water channels.
    Full crank grind/polish
    Full crank assembly balance inc pistons, rods flywheel and clutch
    Cylinder head decoke
    Cylinder head pressure test
    Cylinder head repair to snapped water pump bolts
    New valve seats cut
    Cylinder head reface
    New cylinder liners measured for protrusion, recorded and adjusted accordingly. New piston ring and piston clearances checked and adjusted as required. Liners final fitted In correct protrusion orders with new seals and clamped. Crankshaft trial fitted to block checking. adjusting bearing clearances as required. Crankshaft final fitting using suitable assembly Lube. Piston rod assembly trial fitted for bearing clearances check and adjustment. New piston ring, piston, rod assembly final fitted with assembly lube. Piper camshaft inspected and
    fitted. Crankshaft and camshaft end float checked. New timing chain and tensioner fitted, cam timed to std setting. Distributor and gear fitted to correct std timing with a new seal. Cam followers checked. polished and fitted with lube. New refurb oil pump kit fitted pre filled with suitable lube.
    Cylinder head fully overhauled inc lapping of valves, new stem seals refitted up with uprated valve springs, new gaskets and water pump Inlet and exhaust manifolds ?fitted with new studs lock nuts and gasket. tubular manifold requiring modification.
    Cylinder bead fitted to block using new ‘uprated’ head gasket and bolts, installing checked, cleaned push rods and fitting overhauled, strip, cleaned, polished shaft, refaced tappet faces and new ‘plugs' rocker assembly.
    Valve clearances and camshaft timing measured and adjusted as required.
    All freshly prepared engine covers, brackets ect fitted Inc oil cooler take off plate and pipes, with new nuts, bolts and seals as required.
    Carburettor stripped, cleaned, painted and fully overhauled with a new gasket kit, then fitted with a new spacer and gaskets. New engine wiring loom modified to eliminate perk fan requirements and ?fitted.
    Bottom pulley with new efi timing sensor fitted to correct tinting inc new aux drive belt.
    New crank seal fitted, lightened and balanced flwheel and clutch assembly fitted using new bolts.
    Gear box fitted along with starter motor and freshly prepared mounts, brackets ect. Wiring loom correctly routed ensuring security and movement.
    Hybrid turbo fitted with new braided oil feed and drain pipes.
    Engine bay fitted up, all brackets pipes fixings cleaned, painted as necessary, all new nuts, bolts ect to ensure visual appeal. New accelerator cable kit, battery terminals and power cables fitted.
    Power unit refitted to vehicle using all new nuts bolts jubilee clips ect inc new exhaust fitting kit.
    Modified induction and breather systems arranged and fitted
    intercooler, oil cooler and bumper modified fixings made and fitted to best possible std.
    Vehicles starting charging electrical system fully repaired rewired as required.
    Engines compression, oil pressure primed, checked and recorded. Cooling system filled using long life coolant mix, air bled. Engine started and run up to temp, checking for noise, leaks correct fan operation.
    Tappets reset, head retorqued and oil changed.
    AEM boost controller installed and set up
    Vehicle road tested, then rechecked for leaks ect. Miles put onto engine as a brief run in period.
    Full testing c/o setting up the boost controller, checking adjusting carburetion as required whilst monitoring for any issues/det.
    Cylinder head - 73.34mm
    All bearing clearances ring gaps good
    Compressions, cold engine 6hrs old 150psi +- 3psiacross all 4 pots
    Oil pressure, hot engine 30 psi idle - 50 psi at 4k
    Boost - 1bar engine
    Afr -wot 11.8 -12.1
    South Wales
    ll let the pictures do the talking
    Non-member Andyturbo!'s Avatar
    Oct 2011
    Leeds west yorkshire
    Looking great pal nice and fresh
  41. #41
    South Wales
    Cheers roll on efi
  42. #42
    Non-member gttjames's Avatar
    Cambridge
    wow, much prefer the car now as to the earlier pictures. Great job
  43. #43
    South Wales
    Quote Originally Posted by gttjames View Post
    Thanks plenty more to come
  44. #44
    Non-member bood's Avatar
    May 2011
    wow thats a great turn around.
    gotta love a black one
  45. #45
    South Wales
    Quote Originally Posted by bood View Post
    its not quite at the same standard as yours, yours looks amazing
  46. #46
    Non-member kial's Avatar
    Jan 2011
    Jersey, C.I.
    looks really good buddy!
    really like the intercooler piping is it custom made??
  47. #47
    May 2011
    thats very kind of you but i wouldnt put yours down its looking quality to me
  48. #48
    South Wales
    Quote Originally Posted by kial View Post
    No it's not custom made its just the ktec kit! It will be coming off soon though so a smaller cooler can go on so I can fit a standard front bumper
  49. #49
    Non-member 5 turbo's Avatar
    Mar 2011
    man fresh black paint looks soooooooooooo good
    cracking progress fella, just hope the exhausts are coming off
  50. #50
    South Wales
    Quote Originally Posted by 5 turbo View Post
    It sure is having trouble finding a 2.5 bore with a 3 or 3.5 tailpipe at moment though! Will see how my next pay is looking and may go custom made
