fse fuel pressure regulator..
what should this be set to on idle and how do you go about setting this up ok?? would i be able to get away with using this instead of changing the injectors to run more than 16 psi of boost, thanks
Re: fse fuel pressure regulator..
Have a read of this, further down the page.. https://www.rtoc.org/boards/showthread.php?t=20401
As for the base fuel pressure, see what it is now (on the standard reg) then fit the FSE to the same.. Then I'd add no more than an extra bar of fuel pressure IMO.. May work may not. You'll need some sort of lamba sensor and poss det can's whilst you turn up the boost
O and just to add you should remove the vac hose from the FPR to get your fuel pressure set point on the orignal set-up.
hope that helps.
