right my mates gt turbo is having problems, its got the standard t2 turbo, group a fuel pump, new fuel regulator and filter, its running 8 psi standard boost ive fitted my afr meter to it and its reading 14 which is too high also when on boost its not dropping down its going up to 15/16 and the turbo is stalling! Fuel is getting though ok ive checked that also cleaned the carb out and cleaned the small fuel filter but its still doing it? I had the same problem with mine which turned out to be a badly built carb! This carb is standard and has been serviced 2 months ago. Any sugestions? Shouldnt need a bigger jet when running 8psi?
Thanks guys.
