Trying to figure some vac pipes out, can anyone advise if i do the following this would be OK. Half the stuff was missing off this engine before I rebuilt it.
If i run pipes A to dump valve and turbo actuator and B to boost gauges see below:
Not sure what goes to A and B, also there is a small vac connection near C on the bottom of the carb.
Am i correct in joining the carb lobster and the bottom pipe as shown, also the pipe circled has always been blocked off, is this correct.
Stupid question is X fuel inlet?.
Any replies greatly appreciated.
