where do these pipes go ?
Can anyone tell me where marked the pipes go to
thanku
Re: where do these pipes go ?
block 3 and 4 off itll be fine................
They run in the loop for the carb and turbo coolant hoses.
4. From pump to inlett (can be run straight to point 1.)
1. From inlett to this spout.
2. To turbo in.
3. To turbo out.
But as Eugein said. You can loop 3 & 4 and leave it all off. Go from 4 to the turbo and back to 3... Depends how much of the coolant circuit you want to use.
