Before I fork out for new calipers/discs/bearings for the rear, just need to double check this, the braking was fine a couple of years ago when the car was on the road and the only thing changed now is that the back end is raised up two inches would this cause the rear brakes to be at so low on efficiency or is the calipers seized up due to not being used for so long. Going to adjust the hand brake cable as well as that was rather low on effiency as well
Would the brake bias have to be moved towards the back of the car to counter this change in height?
