Results 1 to 20 of 20
    Mar 2011
    engine bay puzzle!
    hi,
    i need some help! im not really sure, but i think i'm missing some vacuum hoses or something?
    ive uploaded some pics, there are some nipples with nothing on on the turbo actuator, the carb top elbow and the carb itself. also, the choke cable wont stay attached. the clip is missing, and when i clip the cable end on to it, it seems to spin really easy? should there be some resistance or is this norm?
    Non-member tubbyG's Avatar
    Dec 2010
    Re: engine bay puzzle!
    the bracket where your choke cable is cable tied onto looks extremley bent in that pic - looks like someone has leant on it! it should be at right angles to the carb
    -the actuator port looks ok, many have this port open when running the cup mod.
    -carb top should definetley be blocked off if not using it. think my oe boost gauge connects there
    Non-member scratcher's Avatar
    Milton Keynes - ish
    The carb top one should go to the oe boost gauge and the fuel pressure regulator. Follow your fuel pipe back and you'll see it down the drivers side turret.
    Oh, and the choke cable clips are the same as the ones behind the dash. There's easy to grab ones behind the ash tray.
    I think they're the same anyway?
    Mar 2011
    nice one! ive had a dig around and found two hoses just flapping about doin nowt!
    one was from the fuel regulator, and ive put it onto the carb elbow, but theres a t peice on it that goes to nowt now! lol!
    also, ive found another hose, its under the carb, i think its into the manifold?
    ill get some pics up and hopefully someone can help out!
    theres some sort of connection thing thats on a hose between the actuator and carb elbow? any ideas what it is and what it does?
    cheers
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Your first pic is just your bleed valve, this bleeds pressure off acting on your actuator and keeps your wastegate closed longer, upping your boost pressure, adjusting that valve will adjust your boost. dont over do it without knowing the fueling. the 3rd picture should have a little hose coming from your t piece to the brass accelerator jet below it. i cant remember what the manifold pipes are below im sure someone will help.
    Mar 2011
    aha! thats great, cheers mate, looks like i need a new bleed valve, or can i just get rid and put a new piece of hose in?
    thanks again!
    Non-member markey b's Avatar
    Bury St Edmunds
    i recognise that engine.... wouldn't be G779VVK would it
    Quote Originally Posted by frano81 View Post
    thanks again!
    Just replace the vacum pipe ditch the bleed valve it's knackered anyway looking at it it's missing the adjuster so would over boost like that,
    Mar 2011
    Yes it is that engine! Any idea why half the hoses aren't connected?
    Also, who is it that's in love with the tie wraps! There everywhere lol!
    I've sorted the fuel leak now, so hopefully I'll be firing her up soon.
    Just wanting to check these loose ends out incase I end up ****ing something else up!
    Bury St Edmunds
    lol, I did 10k in that car in a year faultlessly, then sold it n the kid popped it almost straight away lol. iirc the inlet manifold coreplug leaked so I just bypassed it hence coolant pipe behind engine, as for everything else it was running perfect when it went and makin 150bhp in a t2 :-)
    Mar 2011
    What do you mean by popped it? Hope your not talking about the head gasket! He told me it would be fine when the fuel leak is sorted and battery charged
    Bury St Edmunds
    it was fine done worry, i did the head gasket just after i sold it, but as far as i'm aware it was fine apart from fuel leak and batt when he sold it, i was gonna fix it up but he sold it before i got chance
    Mar 2011
    Can anyone shed any light as to what the two ports are under the carb?
    I thought they were for the crankcase and brake servo, but they're under those two?
    Non-member gimme5's Avatar
    Dec 2008
    north yorkshire
    if your on about were they come out in a v shape there coolant hoses
    Mar 2011
    No, I've clocked those, the two I'm taking about are like under Neath the accelerator spring
    Dec 2004
    Aylesbury
    You got a pic of the 2 your on about mate?
    Dec 2008
    north yorkshire
    if your talking about the one's below the carb there also coolant hoses (going into inlet manifold back out and through turbo etc)
    Mar 2011
    heres the pic of them. the one on the right has a hose attached that goes nowhere!
    cheers
    Dec 2008
    north yorkshire
    looking head on at picture
    top left brake servo
    one below this goes to waterpump outlet next to temp sensor
    top right breather hose,connects to T-piece that splits off to top of swirl pot
    and telephone hose
    bottom right coolant hose to carb base outlet (one closest to bulkhead
    Bury St Edmunds
    unless the inlet manifold has been replaced, connect that up and you'll make a nice puddle
