Results 1 to 8 of 8
    Tipton
    Innovate LC1- you gotta love em....
    mine worked fine for a bit, sorted out my old mk1 TL a treat....
    then i fitted it to my turbo 2.
    i used a seperate battery, but made a slight boo boo by leavin the LC1 on without the car on for a good few hours.- so the seperate battery went flat. error code 9 ??
    changed the battery, and it was all good. took the car for a drive and at WOT i think the sensor got too hot, cos the reading got 'stuck' and then started reading 22.4.
    so i tried another sensor, it last one run.
    ive recalibrated the lc1 and sensors etc etc several times.
    now it appears to be stuck in a weird cycle. - i attach it to a battery and it starts flashing error code 2 immediately.- no matter what i do!
    tried to reflash it, but didnt have communication with the unit- even though LM programmer detected it was there.
    is it fooked, and will i need to buy a different manufacturers unit?
    Re: Innovate LC1- you gotta love em....
    Speak to Glen @ Graham Goode matey they normally take them back and replace
    Tipton
    i've had it for a while... i bought it in the group buy a while ago.... you still think they'll do it?
    Worth a try
    Tipton
    so is jamming my marrow, balls deep in Angelina Jolie's bottom, but the chances of that are slim too....
    Non-member tonesGTT's Avatar
    Aug 2000
    Non-member BriC's Avatar
    Dec 2005
    I think our minds work very alike
    Non-member Nayls's Avatar
    Weymouth
    I think glenn will sort it,he's a good bloke!
