will my 5 turbo be ok running 20psi on standard pistons im using a t28 roller bearing turbo?
Cant really answer your question with the info youve given..
It's all about the fueling matey
all about the fuelling and cooling
here here... get yourself a wideband lambda kit mate
What turbo u got there ???? I got one myself but havent got round to putting it on yet .... also mate what sice turbine housing u using ? would be interesting to know when it boosts up.
As for will it be safe ?? as all the chaps say its fuelling thats vitally important and also charge temps too i guess. get a wideband kit and get the carb adjusted to fuel correctly for the boost pressure u want .... also as i was told , make sure u measure ur boost at manifold when trying to fuel correctly.
