I have run a 12mm fuel hose from the tank to the pump in the usual manner but being larger it seems to be getting crimped somewhere along the way. Is there any other way of running the feed with out having the pump in the boot? I may be putting the rear seats back in at some point so some solution that would not effect this would be best
What is the small hose that runs across the sender and tees off to the sender? as this is also getting in the way thanks in advance for any help guys
