Changing my oil cooler to a front mounted one, but is there ment to be a washer here?
A awasher should be between the engine and this plate.
On the other sside of the plate you will put the filter which has a washer in it.
As Jimmy says there should be a big rubber O'ring / washer that goes against the sandwich plate to the block it will be the same size as the oil filter one, and you will also need 1 for when you place the oil filter against the sandwich plate which as already said by Jimmy is on the oil filter already
Thanks, so them gaskets should be in my bottom end gasket set?
If not I keep them in stock.
Think ive found it, but the bolt that clamps it to the block just rattles around in the hole. Does this matter? seems fine when tightend up.
Right back again, been looking at my oil sandwich plate and i didnt mention that im changing the standard one to a mocal one. My problem is that the bit that goes throught the sandwich plate and bolts to the block just rattles in the hole, so do i need a different one from mocal to fill the hole? also a bigger rubber seal for it? hope that all makes sence. thanks.
Anyone? what i mean is in my pics u can see the bolt that goes through the hole just rattles around compared to the standard one which is a snug fit.
Yes it should be snug. Think it's a m18x1.5 mocal jobbie from memory
hi right i had this problem with my oil cooler and i phoned mocal up and expalned it to them yes they do the parts for this and it wont cheap about £6 each part but cos i had one part i just needed the other if stick then give me a ring mate 07865199163 chris
M20 x 1.5 is what you need that plate adaptor bolt you have is way to small.
cheers for that.
do u know if they do the gasket for the plate? or what size so i can search for it.
thanks.
hello gary i have sent you a pm mate about the problem you have i have the seal you need and need to be pm"d your address and post code so i can send this to you for free many thanks chrisd
Hello again, right ive got my adaptor now as in the pic james has shown me but how do i fit my oil filter on? there nothing to screw it to.
Errr no, where would i look for the other part?
Is it just a threaded tube James ?
if it is I have one I think, PM me your address Gary & I'll post it out to you.
PS I just had the exact same problem .
It's item 2 in the attached pic, I will see if I can find a renault reference for it only cost me a few quid a few years back prob gone up a bit now though
Found the my original thread
https://www.rtoc.org/boards/showthread.php?t=7940
Yeah pretty sure I have one of those bits in the shed, will have a rummage tomorrow.
