I just got myself some low comp pistons. To see what the difference was I held the original pistons and the new low comp pistons beside eachother.
Seems that the only difference between these two is that the low comp pistons are 1 mm lower in the center than the standard pistons.
I don't know why, but I thought that the difference would be a bit bigger...
Is this be thé differnce between 17 psi and 28 psi??
Has anybody run on that much psi with low comp pistons??
