Results 1 to 19 of 19
    Non-member dave r5's Avatar
    Aug 2009
    pitsea essex
    Turbo specs
    What do u all reckon.
    It's not from china and is quite cheap.
    *GT28 T28/T25 200SX Silvia SR20DET turbocharger Upgrade
    BRAND NEW
    COME WITH 6 MONTH WARRANTY
    Item Description:
    * Our products are 100 % Brand New
    * It*is bigger than factory SR20DET Turbo. Fits factory water lines and oil lines.Banjo bolt M12*1.25
    * Compressor A/R=0.86*
    * Suits T25/T28 Flange
    * Internal wastegate with 8psi actuator
    * Comes on full boost by 3000RPM and continuously pulls power right threw to redline. The factory S13 and S14 Turbo pulls power from 3000RPM but looses Puff by 5000rpm and just dies out, where the*turbo*will keeps pulling power right threw the Rev Range
    * Compressor outlet pipe 50mm, inlet pipe 70mm, 48-trim compressor, intrducer 53mm, exducer 76.5mm
    * Turbo wheel outlet 46mm, outer diameter 53mm
    ** Professional installation is recommended
    * Suitable for single-turbo applications on 1.6-2.2 litre engines,or in twin turbo kits
    on 3.0 to 6.0 litre engines
    ALSO Ideal for: twin turboing a 300zx or a gtr upgrade or nissan pulsa gtir and silvia S13 S14 or S15
    Non-member sieger's Avatar
    assen city
    Re: Turbo specs
    i've got the same , does the job well. on the track i turned it up to 1,5 bar with no problems, leaving a r26r disapointed behind me
    Non-member car.crash's Avatar
    Aug 2006
    Re: Turbo specs
    probs be very laggy.
    Re: Turbo specs
    Sounds like a chinese jobby, get a garrett whacked on
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: Turbo specs
    Im still looking for a t28 and have looked into these im just woried about the bearings
    Aug 2006
    Re: Turbo specs
    some of them chinese copies can have the inners replaced with garret items.
    Non-member TrixNFlix's Avatar
    Preston
    Re: Turbo specs
    Quote Originally Posted by sieger View Post
    Lukas, what power, boost are you running now. When does this turbo start spooling and hit full boost by? Is ithere not too small of a powerband to be used well on track?
    assen city
    Re: Turbo specs
    just looked closer to it i've got this one
    T25/T28 TD04-H TURBO CHARGER INTERNAL WG +FLANGE SET
    http://cgi.ebay.com/ebaymotors/TWIN-...Q5fAccessories
    assen city
    Re: Turbo specs
    about 3000 rpm boost, 3700 full boost.
    im running 1,3 bar boost. that 1,5 bar was for fun (see if the engine would say pop) but it didn`t. With my new engine i will run 1,5 bar al the time ( Big Mod ecu, 350 cc injectors)
    Preston
    Re: Turbo specs
    ahh right so a different turbo to the spec dave posted.
    assen city
    Re: Turbo specs
    yep..
    Oxfordshire
    Re: Turbo specs
    T4 front end on a T25 back end, get it, I could use a good laugh
    Aug 2009
    pitsea essex
    Re: Turbo specs
    I'm already running a t28 from a 200.
    Was just thinking as a spare/new replacement
    But mayb not.
    The comp housing is slightly bigger than mine
    I did actualy measure mine but for got to rite it down
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Turbo specs
    I'd say the compressor is too big dave.
    Re: Turbo specs
    so is the 200sx turbo still the best bet for a road going b18ft 5 then?
    Preston
    Re: Turbo specs
    Why do you want to change dave?
    Aug 2009
    pitsea essex
    Re: Turbo specs
    not wanting to change just prepering for a fatal error down the road, as its eventualy going to happen.
    ive had my turb on for a while now, i paid 80 quid for it, its done 3 track days plus mallory. and at least 25 runs up the strip
    could any 1 link me to a garret t28 thats worth buying.
    Portugal
    Re: Turbo specs
    If you got a B18FT I would go for GT28RS
    Mar 2004
    Salford (manchester)
    Re: Turbo specs
    yeah 53mm inducer is rather large for a c1j, we ran a t04e on the first civic and that was a 53mm inducer, its a 450hp compressor
