Results 1 to 11 of 11
    Non-member richi's Avatar
    manchester-kinda
    driveshafts
    trying to remove the driveshafts from the 5, i have got the big nut off the driveshaft,
    now im trying to get the tie rod end??(think thats the name of it) nut off but its spinning like hell. where is the end of the bolt, i can see the nut on top but the end of the bolt doesnt seem to be on the bottom so cant grab on to eash end like normal any help
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    Re: driveshafts
    It has a hidden captive nut sort of thing going on lol
    Get a jack under the tie rod so it pushes the bolt from beneath upwards, this should lock it into place within the steering rack and allow the nut to be loosened.
    Use a bit of WD40 too...
    That made sense to me writing it, tell me if thats not the case!
    Oxfordshire
    Re: driveshafts
    yep, that made sense to you writing it.
    Sep 2001
    SW PMT HQ
    Re: driveshafts
    well, i know what i meant, whether its good to anyone else who knows
    Non-member tobester's Avatar
    Bracknell
    Re: driveshafts
    Quote Originally Posted by richi View Post
    use a trolley jack on the bottom of the tie rod end to push it back up into the hub, it's a taper fit so this should lock it tight whilst you undo the nut. it mighT be reluctant to come out again, but TAP the hub with a hammer and it should drop out.
    Sep 2001
    SW PMT HQ
    Re: driveshafts
    Quote Originally Posted by tobester View Post
    thats what i said, to a degree...
    Bracknell
    Re: driveshafts
    I knew what you meant.
    Dec 2004
    Aylesbury
    Re: driveshafts
    No need to undo the tie-rod nut to get the driveshaft out, undo the shock mounting bolts or the bottom ball joint and pull the hub away from the driveshaft them pull the shaft out.
    Re: driveshafts
    Undoing the track rod end won't help, just taking off unecessary parts.
    manchester-kinda
    Re: driveshafts
    see i had that idea lol, i started undoing the two bolts at the bottom of the shock where it attaches to the back off the disc sorta
    then i got worried in my mine because the spring is under tension the second i undo the 2 bolts it would slam the suspension down
    manchester-kinda
    Re: driveshafts
    but whats a ballache now is i will have to tighten the tie rod end back up as its a bit lose now lol, so will still have to try the jack trick
