Results 1 to 5 of 5
    Non-member Harri's Avatar
    Finland
    differences in phase 1 and phase 2 turbo oil feed and return
    Hi,
    are there differences in phase1 and 2 turbo oil feed and return connections?
    1) the oil return connection to the oil pan, is the phase2 diameter bigger?
    2) T2 oil inlet connector (from oil feed hose to turbo), it should be same in both, right?
    The reason I´m asking this is because I bought braided oil feed hose and sfs oil return hose (the 90 degree bend) for my gtt. There were only two problems, the oil feed didn´t fit to my T2, and oil return hose was too big.
    Sittard, Netherlands
    Re: differences in phase 1 and phase 2 turbo oil feed and return
    Yes there's a difference... the oil return pipe to sump is indeed bigger and shorter for ph2 and the oil inlet is the same for ph1 and 2...
    Non-member Shane P's Avatar
    Jan 2006
    The braided oil feed hose should have come with an adapter to fit the T2
    Tipton
    Quote Originally Posted by jantheeven View Post
    FAIL!
    the ph1 oil feed is different.
    infact ive seen 2 sizes of ph2 oil feed OE as well
    FAIL!
    Oh yes... that's true... my new turbo (ph2) needed a different feed, so I had one custom made
