Results 1 to 7 of 7
    Non-member xchipx's Avatar
    Sep 2010
    Easiest way to take carb off? Any special tools?
    I do have the Haynes manual for the R9 but that doesn't go into any details at all regarding removing the carb on turbo models.
    Have just ordered carb rebuild kit which should be here in next day or so
    Are there any special spanners or anything needed before i attempt this? I amhiping that any gaskets that need replacing, will be in the kit ?
    Thanks guys
    Non-member modfather's Avatar
    Re: Easiest way to take carb off? Any special tools?
    Quote Originally Posted by xchipx View Post
    Thanks guys
    if its anything like the 5gt turbo then its just a couple of bolts holding the carb to the manifold and a couple of pipes
    Quote Originally Posted by modfather View Post
    13mm bolt for the 2 x bolts that hold the carb to the inlet manifold, remove the pipes going to the carb, remove the fuel line, detach the accelerator cable, detach the choke cable, accelerator cable spring, coolant pipes to carb base, remvoe the carb lobster.
    Job done, the carb gasket set will and should come with all the required gasket's think the RTOC shop one comes with the green seals for the carb throttle butterfly.
    Non-member SCHWARTZ's Avatar
    Wallington south london
    what he said
    Tipton
    actually 2 x 12mm nuts... if its 13mm they have been changed...
    Sep 2010
    Well carb is off now, was actually a lot easier than i was expecting. ( oh and it was 2 X13mm nuts )
    Now its time to go strip it down.
    Strange, i think my car might have an electric fuel pump, is that normal?
    Jul 2003
    I think my car might have an electric fuel pump, is that normal?
    Under the car, near the fuel tank - Perfectly Normal
    Somewhere in the engine bay - Odd?
