Afternoon peeps,
Just after a little advice really, last week I had a slightl problem with my 5 in that the rear shock absorber on the drivers side decided to snap Now at the time of driving I was doing the speed limits. Anyway I eventually pulled over as the banging from the rear of my 5 was worring.
So I had a look under the car with my torch and couldn't really see much but then this was about 12am in the morning so light was not good. I got the car home and decided to have a look the next day after work and first look I thought I had bent the shock absorber piston rod. Car then chucked on axle stands and wheels off and started to remove the shock absorber for a better look only to find that the piston rod had snapped flush with the top hat eye connection.
I don't see this as general wear and tear, the shocks are in very good condition both in appearance and working condition and haven't really been abused. I see this as a manufacturing fault but I am after peoples opinons on this.
Now I have contacted spax and sent them pictures of the damages. Now the suspension falls outside of its 2 year warrenty but I know that under the sales of goods act 1979 that I really have up to 6 years.
Any advice or suggestions as to the cause? and what to do?
(Let me add that I am going to be raising the rear of the car by about 1" but surely being shorter dampers and being lowered this should have not caused the damage it has the other damper is fine)
