Results 1 to 40 of 40
    burton on trent
    simple r5 engine bays
    ok, over the years ive noticed many renault 5's with simplied engine bays, these often having relocated water circuits, and the oil breathers setup simplied down to 1 or 2 hoses..
    I just wondered if folks fancy posting a few pics as at the moment mine is very cluttered and i just feel its an epic mission to sort things when they go wrong.
    a good example being marks campus
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    Re: simple r5 engine bays
    Non-member J8TRO's Avatar
    Stourbridge
    JRP that's a mess.............sort it out.
    Nov 2001
    Hogwarts
    Quote Originally Posted by J8TRO View Post
    Sorry sir
    Classifieds Moderator
    Mar 2004
    thats better jrp, less is more
    Nov 2001
    Hogwarts
    Stourbridge
    I like what you did there..............
    Nov 2001
    Hogwarts
    Non-member Shane P's Avatar
    Jan 2006
    I just started with the simple things :
    Removed Anti-perc fan and wiring
    Removed overboost wiring
    Removed most of the actuator piping
    All unshielded wiring placed in convoluted tubing
    All wiring from centre of bulkhead is attached to the bracket on the side of the head
    OE water system and breather system seem tidy enough for me
    Non-member SCHWARTZ's Avatar
    Wallington south london
    love it. looks smart
    Non-member benj88's Avatar
    Mar 2010
    Looks verry nice, I'm guna make my bay more oe
    Non-member Hoolio's Avatar
    Wallingford
    That does look pretty good, makes mine look grubby
    Dec 2004
    Aylesbury
    If you think the campus is tidy you wait for the volvo 5, i've been working on it now for the past 2 weekends. All will be reveiled when i update the project thread.
    Non-member TrixNFlix's Avatar
    Preston
    About flippin time!
    Dec 2004
    Aylesbury
    About flippin time!
    I know mate!
    Its been a while since i've touched it so i've pulled it apart and gone over everything and changing bits i'm wasn't really happy with.
    Engine bay is being given a bit of a revamp
    get some piccys up
    Dec 2004
    Aylesbury
    get some piccys up
    I will do mate once i've made abit more progress, i'll stick them in the prject thread for the red 5.
    ace
    burton on trent
    mark, in that pic wheres all the oil breather system, there seems to be no oil pot, and no breathers off the back of the inlet, car to share
    Dec 2004
    Aylesbury
    The oil breather pot and pipework from back of inlet manifold (plus one-way valve) has all gone. I've simplified it to have the breather straight out the rocker into the catch tank, if i get any probs i'll mod a fitting into the blanking plate on the front of the engine to go to the other catch tank outlet.
    Non-member jimmy_b's Avatar
    May 2010
    in the garage
    thats mine, really should update the pics
    burton on trent
    was looking at yours yesterday jimmy, really tidy, , again another one of interest, have you also pretty much removed all the oil breathing sid eof things, cant really tell in that pic.
    May 2010
    in the garage
    heres a more up to date pic.
    ive still got my std breather system, i have a catch tank but feel it would be too much in the engine bay
    Non-member Tricky's Avatar
    The Woods
    You can get rid of loads of stuff - run the breather system open, like the cup cars. You may have trouble come MOT time. Lose loads of water pipes too. I didn't run any to the carb or turbo.
    burton on trent
    ah thats a point, never realised there wasnt any to the carb in most the pics.. I presume its more for cold climates where they suffer carb freeze etc.
    The Woods
    The hoses to the carb base didn't really make much difference to running in cold. That was mainly down to my intercooler stuffed in the grill.
    burton on trent
    just trying to work out exactly what you do to loose all them oil breather hoses, and the oil pot, as surely your left with the pipe it sits on that returns back to the sump
    The Woods
    You can run the pipes from rocker cover and sump into a pot. Fuk the rest of the sh1t off.
    Can even block the sump off and just run out the rocker. Depends how much your engine wants to breath.
    burton on trent
    Quote Originally Posted by Tricky View Post
    I presume you then also have to block the inlet up at the back.. In my books id prefer less stuff in the bay so i can keep a better eye on what matters
    The Woods
    Cant remember mate - I've had a few...
    Mar 2004
    have you looked in the carb inlet and outlets, most are so corroded its a wonder if any water travels through.... alot of are cars have moved on from daily drivers to weekend and fair weather, mine wont be out in the bitter cold and if i am getting some freeze i'll cardboard the intercooler..
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    place it in a cornflake box....
    Non-member philr5t's Avatar
    Dec 2008
    tadworth
    my bay
    Markey, what have you used to block the sump breather? Also, is that a knock sensor bolted to the head, near the actuator?
    I love threads like this, its amazing what different people can do with there engine bay! Krissy M has a really nice empty engine bay!
    My bay, needs a litte tidy up and only recently added the oil seperator pot back in situ
    Non-member fidos got a raider's Avatar
    Almost back to how you had it before james
    Quote Originally Posted by fidos got a raider View Post
    Getting there still a few more things to change in the engine itself
    Stapleford
    lovely engine bay dude just a question where does the blue breather pipe off the carb go? looks as though it heads to near the rad? mine hasnt got a pip on thats why i ask
    Non-member 5teve L's Avatar
    RH12
    Quote Originally Posted by matty j View Post
    It's an overflow in case the diaphram splits IIRC, it directs fuel away from the hot manifold.
    Stapleford
    best to get it re directed then i guess lol
