Results 1 to 9 of 9
    Non-member R11_DAVE's Avatar
    Apr 2010
    advice
    I just used a spark plug chaser and a few bits of metal fell into the engine. Will these burn out or shal i change the oil and filter
    cheers
    Ivybridge
    Re: advice
    Quote Originally Posted by R11_DAVE View Post
    cheers
    They will not burn out. If metal has entered the cylinders through the spark plug hole you need to get ALL of it out, or they will potentially knacker your valves, cylinder head and turbo. Changing the oil will do nothing.
    I would remove the cylinder head and hoover the bores out, then bar the engine to TDC, then flush the cylinder with WD40 to be sure. You will need a new head gasket if doing this.
    Why were you using a plug chaser (i assume you were re-tapping a thread?) with the head on?
    Non-member robbie506's Avatar
    liverpool
    Re: advice
    big problem bud dont run it at all!!!
    Classifieds Moderator
    Mar 2004
    Re: advice
    as above you need that out..
    Aug 2004
    Re: advice
    & join the club. simples
    Tipton
    Re: advice
    vacuum cleaner down the sparkplug hole.....
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Re: advice
    high pressure air line with valves closed, and try a hoover. Try looking inside the cylinder, you should be able to see the surface of the piston when its near tdc.
    Its worth spending plenty of time removing the swarf, otherwise itll cost you tenfold in the long run.
    Non-member philg's Avatar
    Aug 2009
    Newcastle
    Re: advice
    agree, with all the above, i dropped a spark plug nipple down there years ago, was not to sure if it had went in or not. It had
    Ended up head off, new gasket, head skimmed, new oil and 2 turbo ruined through the oil getting contaminated.
    Apr 2010
    Re: advice
    well i adapted my vacume cleaner with a straw and cant see any silver bits. i have taken her on a good run (about 30 miles down the M5 and back).Ill use her tomorrow and see how it goes.
    Thanks for the help Mark
    Dave
