ive done some mods on the inlet manifold, ove welded it up to fit 2 carbs. i have not yet run it with them on. does any1 know if this can be done? they fit perfect and i have put pipes and throttle on ok but dont want to use it yet.
Its been done before a few times, don't think its been very successful at all though.
Just trying to get it to work right and fuel right from what i heard/seen, i've known of a few people try it.
To be honest mate for the hassle your not going to gain much from it, more advantage going EFI than twin carb
nah, just 100 shot of NOS Mark
Two carbs = double the headache to jet Good luck getting 300hp, its not easy with the old c1j.
one carb is a nightmare never mind two.
I once toyed with i idea of using a dellorto dhla 44 carb, it has a seprate enrichment circuit for boost and lots of diffrent auxiliary tubes and venturis.
No it was used on a lotus esprit turbo, its a twin carb like a 45 weber. I did mention it before but got shot down in flames even though the guy who shot me down had never tryed it.
a ruff spec of what i got an tell me if 300 bhp is in target,
forged pistons+rods
steel liners
piper 300 cam
stage 3 k tec head
tubular manifold
k tec ballistics turbo
if the 2 carbs work
side exit
2 1/2 down pipe
more but lost the paperwork
I think the problem you will have is knowing which carb to tune?? i think it'd be easier with a tubular manifold then you could measure egt in 1 and 4 and not have the gasses mixing. Or have seperate lambda sensors. cheapest option probably to do identical adjustments on both but it wouldnt be ideal, carbs never seem to tune the same.
IMO the effort involved your probably best going efi.
What does a stage 3 head from K-tec consist of these days? a little work with a die grinder? Whats a ballistics turbo? What tube manifold do you have? the o.e cast one is pretty good. If I were you I would aim for a genuine 230-240 first before you go chasing the magic 300hp. Are you trying to achive this on race fuel?
its not that im just buying it to say it really just thought better bit for a little more reliability. also my mate who is a welder by trade has fitted it and got the pipe work accelerator cable etc on seems like it will work messin witt it on the stand working, just see what goes when it goes in. ill prob be at silverstone in it so hope it works
If you're chasing that kind of (genuine) power you won't have any kind of reliability, trust me!
